Value Display - State Format
Sathishkumar_C
I want to show multiple icons with respect integer using "Value Display and State Formatting".
Ex:
1 - Icon 1
2 - Icon 2
3 - Icon 3
Others - Icon 4
But, I don't want to display integer value(1, 2, 3, Others).
1 ACCEPTED SOLUTION
Mukul
(To:Sathishkumar_C)
You have two options
1) use a legacy value display widget, it will automatically display the icon only on the basis of value.
2) if you are using ptcs value display widget, you can apply a tweak. go to style properties of that widget go to Base->item value->color. put the color value as white(matching with your panel/container background color). In this way, the user will not be able to see the value. it will just bring up the icon. Make sure the style definition which you create and put for every value in state definition only has the required icon and no other background/text color.
Mukul
(To:Sathishkumar_C)
Thanks for your suggestions.
