Value Display State Formatting TW 8.5.0-b12
atidwel
I'm not able to configure the state formatting option for the new Value Display widgets - it's not even listed in the properties. Will the new Value Display widgets have a State formatting option available? I know the old ones do, but those will be deprecated soon, or so it says... Any help appreciated!
VladimirRosu
(To:atidwel)
@atidwel The previous post already provided the necessary answer, but I want to make you aware of a workaround that would work with the new widgets as well, until they get official suport for state-based formatting.
The state-based formatting modifies certain HTML attributes/css depending on the input value for a widget.
To achieve this you can use the CustomCSS mechanism and one expression. By using an expression with an input parameter (widget input value) that outputs a string (the custom CSS class name) you can set the CSS class for your widget depending on the input value. Hint: you can use multiple inputs, from other widgets, to set your Class.
4 REPLIES 4
The old Value Display widget will be there in 9.0 release as well. Adding state formatting to the new one is being targeted for a release later this year.
VladimirRosu
(To:atidwel)
slangley
23-Emerald II
(To:VladimirRosu)
Hi @atidwel.
If the response provided by @VladimirRosu answered your question, please mark it as the Accepted Solution for the benefit of others on the community.
We appreciated your participation!
--Sharon
slangley
23-Emerald II
(To:atidwel)
Hi @atidwel.
I have marked the solution for your post.  If you disagree with the solution selected, please provide more information and I will remove it.
--Sharon
