Hi, Can anyone explain how can I check the version of the C SDK and CMake that I am using?
Hi @SS_10329829 ,
You can tell the C SDK version by looking at the folder name of the C SDK you downloaded, or there should be a version.properties file included in the C SDK, open that in editor should tell you the version of C SDK.
For CMake, ensure that the CMake installation's /bin path (e.g. C:\Program Files\CMake\bin) is added in environment variable, open a command line tool and type "cmake --version" to check the version of CMake installed.
Try to find this information in the following sources:
Hi @SS_10329829 ,
