Vertical divider
VaibhavShinde
Vertical divider
Hi ,
I have to use vertical divider, how we can draw this in TWX 8.5.2 ? i see we can easily use horizontal divider but i was not able to do it vertical.
I made it Vertical using CSS , just i applied css to existing divider and rotate it by 90 degree.
thanks
6 REPLIES 6
slangley
(To:VaibhavShinde)
Hi @VaibhavShinde.
Without knowing what widgets you're using, etc., you might want to check for the possibility of adding a border.  If this doesn't help, please provide some specifics regarding what you're trying to divide: containers, widgets, etc.  A mock-up would be helpful.
--Sharon
hi,
just i am looking for dividing the widgets using divider widget, but it will be vertical line.
just see below img...wirh vertical line.
thanks
Hi @VaibhavShinde
You can insert new container between two widget and change the color of container. (PFB PNG for reference)
/VR
velkumar,
i cant use this, because i already used Divider widget for Horizontal line which is a very thin line, now just i want it vertically.
why we dont have divider widget for vertical line.?
thanks
slangley
(To:Velkumar)
Hi @VaibhavShinde.
Per Velkumar's post, you can add a container.  The container will need to be set to a Fixed size of 1 (or more pixels) as needed.  You can set the color to match that of the horizontal line.
--Sharon
thanks
