Visual SDK - Gulp Error - task_modifyPtcsMoment
Zetoine
In the official tutorial the steps are 4:
  1. Open a command prompt, then change the current directory to the location on your system where you extracted the SDK utility:
    cd twx-wc-sdk-utility
  2. Run the following command to install the utility:
    npm link
  3. Change your directory to the simple-el-widget/ folder that you created earlier (previously downloaded and unzipped
    cd simple-el-widget
  4. In the widget folder, run the following command to create the extension:
    mub
    and i've the error :
    exec error: Error: Command failed: gulp --e --wd D:\WORK_THINGWORX\simple-el-widget
    [11:46:40] 'task_modifyPtcsMoment' errored after 2 ms
    [11:46:40] Error: ENOENT: no such file or directory, rename 'D:\WORK_THINGWORX\simple-el-widget\tmp\build\wc\ptcs-moment\moment-import.js' -> 'D:\WORK_THINGWORX\simple-el-widget\tmp\build\wc\ptcs-moment\moment-import.js.sdk'
    [11:46:40] 'default' errored after 6.84 s
    could you help me ?
Zetoine
(To:Zetoine)
I forgot to notice that i've no 'tmp\build\wc\ptcs-moment' folder , i've no 'build' folder at all in 'tmp'
in Thingworx 9.2
npm 8.6.0
node 14.16.1
VladimirN
(To:Zetoine)
Found an article with a similar error - "No such file or directory error during Navigate configurator run for PingFederate SSO": https://www.ptc.com/en/support/article/cs363187
