Has anyone integrated Walk-me with Thingworx, I know it is possible with Windchill.
Not sure if this is gonna help, however you can try adding walkme script to index.html and see if it works.
As always, try on test/dev environment first.
Shirish
It looks like Walk-Me has a full rest api available which means it is possible.
I'm thinking you are referring to: https://developer.walkme.com/reference#getting-started-with-your-api
Hello Pai,
I already have walk-me snippet(script) which I have integrated in Windchill. In Thingworx I am not sure in which file I need to embed this script.
Not quite sure what you are referring to as I'm not familiar with the walkme api
but using the ContentLoader functions you should be able to interact with the walkme api directly.
Uncertain what you mean by what 'file' needs to be embedded.
Shirish
I have already done that Shirish, so I have achieved that onload of mashups walk-me feature works. Now I want to have a label or button caled Help and on click would want to launch the walkme feature.
