Weather App with Arduino Uno | ThingWorx
Thetowen
Is this gone cant find the example anywhere?
Cheers
8 REPLIES 8
dupatel
(To:Thetowen)
@Thetowen You can refer the ThingWorx Youtube channel links for details -
https://www.youtube.com/watch?v=-ncCMHHS7CQ
https://www.youtube.com/watch?v=3wvs56TnpTU
Hope it helps.
-Durgesh
Thetowen
(To:dupatel)
Thanks Durgesh I've seen them but it doesn't give a copy of the code??
dupatel
(To:Thetowen)
@Thetowen  It seems the documentation location has been changed and I am not aware of it. There are existing post which you can review and see if this helps.
https://community.ptc.com/t5/ThingWorx-Developers/Open-weather-app-tutorial-problem/m-p/502396
https://community.ptc.com/t5/ThingWorx-Developers/Weather-App-with-Arduino-Uno/m-p/502264#50953&_ga=2.248220487.1965773299.1519212370-1370363342.1519212370
 Meanwhile, i am checking internally if I can help you with the documentation location.
-Durgesh
Thetowen
(To:dupatel)
Durgesh,
I think I know what the issue is. I'm sending a http instead of a https request. Is it possible to use http request on Thingworx 8.2?
Cheers
dupatel
(To:Thetowen)
@Thetowen It should work with http as well.  Could you please provide more details how exactly you are making the http call and what is the error you are getting in application logs.
-Durgesh
Thetowen
(To:dupatel)
dupatel
(To:Thetowen)
@Thetowen It could be due to the way the development instance has been set up with SSL. So, do you see any problem if you make request with https ?
Also, as per confirmation from Academic team that this course has been retired and is the reason for unavailability of documentation on this topic.
-Durgesh
Thetowen
(To:dupatel)
Durgesh,
If you copy paste the above links in your browser you'll see that the https works ok but the http doesn't. As  I'm using an Arduino dealing with SSL certificates etc would be very difficult.
