Does someone knows the status of the improvement https://www.ptc.com/en/support/article?n=CS254257&source=snippet ?
I have a very similar need for the UI design.
Sean
Hi @seanccc.
It is not expected that updates will be made to the Accordian Widget. Instead, the new expand/ collapse feature on flex layouts in ThingWorx 8.5 and above should help with this. You can either use the responsive container, or set a fixed width, or set a min/max width these containers can take.
In the next release of the product, can will also have the ability to overlay these layouts/ containers on top of each other.
Regards.
--Sharon
This JIRA is still in the product backlog with no current planned release. I have PMed you about more details - I can add you as an interested party to this improvement.
-Chris Kaminski
Hi @seanccc.
Regards.
--Sharon
Hi @seanccc.
If the previous response answered your question, even if it wasn't the answer you were hoping for, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
