What version of TW Platform is the latest Edge SDK compatible with
gseq
2-Guest
Hello TW,
We are in bit of a bind. I'm running a legacy version of TW and have ported the Edge C-SDK available at that time for use on of our devices.
PlatformSDK
6.0.31-2-1-261
The latest available platform is 1.3.1.957, updated on Sep 4, 2015, according to marketplace.
Can I run C-SDK 1.3.1.957 on Thingworx 6.0.3.
There are two reasons for this:
  • There is a networking bug in the 1.2 C-SDK which was resolved here.
  • Server side has already been setup.
Gerard
Aanjan
9-Granite
(To:gseq)
Yes, it is compatible; you should not run into any issues.
I think that better you open a support case for this kind of question.
Aanjan
9-Granite
(To:gseq)
Gerard, the BSD socket error fix was patched on to the CSDK 1.3.1 as well. You should not have any issues using the SDK with the platform. On a side note, we have the release notes for all Edge products in the Edge Help Center under the 'Welcome' section.
gseq
2-Guest
(To:Aanjan)
Thanks for clarifying that, Aanjan.
Is it ok to run CSDK 1.3.1 on TW 6.0.3?
Aanjan
9-Granite
(To:gseq)
