I need to download the next extensions to test Kinex with Thingoworx 8:
ThingWorx Manufacturing Apps Extension, ThingWorxManufacturingApps-8.0.1-02-extensionbundle.zip,ThingworxManufacturingApps-8.0.1-02-extensiondependencies.zip,ThingworxManufacturingApps-8.0.1-02-extension.zip.
Regards
Laura Garcia: You can download the Manufacturing App from PTC Download Page
PTC Software Download -> PTC Smart Connected Applications -> ThingWorx Manufacturing Apps Extension ->Most Recent Datecode
-Durgesh
If you want to try 30 day trial version, you can download from below link. (Express version is renewal but limited capability and Developer Kit is full version license expires after 30 days).
https://www.ptc.com/en/thingworx/manufacturing-apps/Dashboard/Get-Started
You may have to register before you download. The above page has training contents as well.
Varathan
Thanks Varathan, but I can see the sections that you mention, can you share a link?
Sorry I can´t see that options in the page
The Fermium/Express version can be downloaded from this link below
The Developer Kit is from here..
https://www.ptc.com/en/thingworx/manufacturing-apps/Dashboard/Download-Developer-Kit
Varathan
Thanks a lot for your help, I had to register to download the files. Currently I have installed Thingworx 8.0 but with MSSQLServer 2014, If I try to install the Manufacturing applications Postgress will be installed and I can avoid this, I just to add the extension on the thingworx composer, that's the reason because a looking for the zip files for the extension, do you know f is possible to download specifically this files?
I really will appreciate for your support, thanks in advance.
In that case you need only extensions. Your access to different PTC software depends on entitlements. If your entitlement allows, you should able to download from here.
https://support.ptc.com/appserver/cs/software_update/swupdate.jsp
You will find it under PTC Smart Connected Applications -> ThingWorx Manufacturing Apps Extension ->Most Recent Datecode
You will also require proper license file which includes MFG APPS which should be downloadable from the license site if you have entitlement.
Varathan
Hi Laura.
From a review of your entitlements, you do not currently own a license for ThingWorx Manufacturing Apps. You will need to reach out to your sales contact to obtain one.
In the meantime, if you wish to take a look at the Freemium/Express or Dev versions available at the links Varathan provided, you will need to install it on a machine that is not already running ThingWorx. Note that your Support login can be used for accessing this site. Additional information regarding installation of these versions is available in the ThingWorx Manufacturing Apps Setup and Configuration Guide available on the support site at https://support.ptc.com/WCMS/files/173133/en/ThingWorxManufacturingAppsSetup_8-0-1.pdf.
This site may also be helpful in answering questions regarding ThingWorx Manufacturing Apps: Manufacturing Apps
--Sharon
