The article you are trying to access is permanently deleted.
Hello All,
I'm using Thingworx Flatform 8.3 with postgresql database,
Can anybody help me answer this question?
Thanks and Best Regards.
NBHD.
Everything it's stored on the Database, the only things which aren't stored are FileRepository content and at starting on some versions the password/appkeys information.
@NBHD207 I just wanted to follow up with you to see if the previous response was helpful for your question.
If so, please indicate the appropriate response as the Accepted Solution for the benefit of other Community members who have the same question.
Vibhuti
