This article
claims that the infotable selector is available in Thingworx Utilities Core. However, when I imported the 9.6 version, the infotable selector widget is still not available. I downloaded other versions and it looks like the selector was last available in 9.3.
Is the infotable selector extension no longer available or has it been moved to another download?
Hello @steve237,
Apologies for my previous reply, as I just found that the extension I have in my ThingWorx was the old extension. Also, I had a discussion with our team, and here is the update regarding the Infotable selector extension:
Also, this extension is available in this github repository (3rd party), but please note that the extension in this repository is four and half years old, and PTC does not provide support for it.
Abhi
Hello @steve237,
I imported ThingWorx-Utilities-Core-9-6-0 in my ThingWorx 9.6.0 environment, and I am able to use the infotable selector widget. Please make sure you downloaded the correct version of ThingWorx-Utilities-Core, which is compatible with your ThingWorx environment.
Abhi
Thanks, for the reply, Abhi.
I think I've got the correct version. I imported ThingWorx-Utilities-Core-9-6-1 into my thingworx 9.6.1 environment.
I downloaded the 9.6.0, 9.6.1 and 9.3.19 versions and as you can see from the first screenshot, only the 9.3.19 version includes the infotableselector extension zip folder, so that is why I think it's not available in 9.6.0 or 9.6.1. The second screenshot shows it's not available in the widget list after I imported the utility.
And this is the download
Hello @steve237,
Abhi
