I have spent an embarrassing number of days wondering. . .
Where is this wiki?
And why is it so hard to find?
Dan,
Don't feel embarrassed - I actually had the same problem for quite a while. I think PTC/ThingWorx are moving around between a couple community/support sites and some things aren't as easily accessible as they probably should be. There are a few documents, but the main one is probably the platform wiki, which you can find below:
Note that you will need to set up a login on the support.ptc.com site, which you may or may not have already.
Dan,
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
