Where to find MQTT Extension to download and import into Thingworx platofrm
krishnak
1-Newbie
   Where to find MQTT Extension to download to import into Thingworx platform
Also how to use the MQTT extension like,
 Connection
 Publish
 Subscribe
Please help me to use MQTT Extension...
6 REPLIES 6
posipova
20-Turquoise
(To:krishnak)
You can download the extension from our "Downloads" section which has the extensions listed on the right-hand side. Here's the direct link:
https://twc.thingworx.com/Thingworx/FileRepositoryDownloader?download-repository=PlatformDownloads&download-path=%2F5.3%2FExtensions%2FMQTT_Extensions.zip
In order to install the extension, in your Composer click on "Import/Export" and then on the "Import" under the Extensions section at the bottom of the appeared list. After the extension has been imported, your composer will refresh.The extension adds a Thing Template MQTT with a configuration section and services which are further described in the Wiki.
Thanks for the link, Sorry to say this we are not able to download. Please provide the correct URL.
Krishna Murthy K P
posipova
20-Turquoise
(To:krishnak)
The link I provided is accessible with the proper support entitlement , just like the rest of our downloads.
Polina
posipova
20-Turquoise
(To:krishnak)
Krishna, please try accessing the link again. We verified the permissions, and you should be able to get to it now!
Polina
Sorry, the page you requested can't be found. You can go back and try again, or start again at home.
Gregory, we now have a Marketplace for all ThingWorx related extensions. Here is a direct link to the MQTT extension.
