https://www.ptc.com/en/support/article/CS325300 reports on a problem with MQTT we are experiencing too (in Thingworx 8.5). In SSL mode, getting "the specified SocketFactory type does not match the broker URI".
That article says "Corrected in MQTT Extension v2.1.2". However, the latest version available for download for TWX 8.5 is 2.1.1. Where can we find 2.1.2 ?
Hi @akartem
You can download the latest version 3.1.0 from PTC website - PTC Software Download - ThingWorx Foundation
/VR
That does not work in Thingworx 8.5. It has minimum version set as 9.0, and I also tried to edit manifest and import - that led to all kinds of troubles "Thing is not enabled" and so on
