What is the difference between ARM and ARM-HWFPU?
Following are two installers for Edge microserver installation with OpenSSL.
MED-61060-CD-054_SP5_Microserver-Linux-arm-hwfpu-openssl-5-4-5-512.zip
MED-61060-CD-054_SP5_Microserver-Linux-arm-openssl-5-4-5-512.zip
I want to install EMS on Raspberry Pi Zero W, which has ARM CPU.
Which installable I should use?
Please suggest.
HWFPU does floating point calculation using hardware and the other does it in software.
