Which widget or extension is used for Time Slot,Share Report,Edit,Update and Delete in grid widget
VikasGadpayle
I have to create this kind of screen in below attach but that widget is not available in ThingWorx Platform I'm new in this platform, can you please help me which widget or which extension  is used for Time slot,Share Report and For Edit,Update and Delete in grid Advanced widget.
Thank in advance
Riya Gajbe
Hi @VikasGadpayle.
This doesn't appear to be just a single widget, but a mix of the Date Time Picker, grid widget, or possibly others.
We recommend you review our training guides available on the Dev Portal.  This would be a good starting point.
--Sharon
8 REPLIES 8
Hi @VikasGadpayle.
--Sharon
Can you have specific Widget or extension name for share Report, Time slot or  Edit, View, Delete in  Thingworx
This helps a lot.
Hi @VikasGadpayle.
As previously stated, it doesn't appear there is one single widget for providing the functionality you need.  But perhaps we're not understanding.  What is your use case that you would restrict you to the use of only 1 widget?
--Sharon
Thanks Sharon , For kind update
I am ready to use two different Widget ,
But i want to know the two different widget name used for that functionality
--Vikas
Hi @VikasGadpayle.
As previously stated, the image appears to be a mix of the Date Time Picker, grid widget, and possibly others.
--Sharon
For sharing report ,which widget or extension is used .
slangley
(To:slangley)
Hi @VikasGadpayle.
Do you have a specific method you plan to use for sharing?  You can download the Mail extension from the PTC Marketplace for configuring email.  There's also a Twilio extension for SMS that would allow you to send a link for accessing the content.
However, these extensions only offer backend functionality--there is no UI component.  You will need to write the services needed for each of the delivery mechanisms you wish to offer.  There is no single widget available to provide the functionality you need.
--Sharon
slangley
(To:slangley)
Hi @VikasGadpayle.
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
Thank you for your participation in the community!
--Sharon
