Java and Javascript use lower camel case naming convention for the variables and methods , but Thingworx seems to use upper camel case for naming the properties and services by default, it need while to adapt and looks a little bit wired for a upper camel case method in Java extension.
is there any special reason for using the naming convention ?
Sean
I don't think there is any specific reason for upper camel case naming convention. Standard naming conventions are adhered to,
