Similarly asked here: Inherited Permissions and Visibility
To put it simply, creating new Things that are based on a specific Thing Template will not inherit the parent's permissions, specifically in my case, the runtime permissions.
How can I resolve this?
Alister
Same here, except its the design time permissions (using Thingworx 7.1).
Any help?
Run Time, Design Time, and Visibility permissions on a ThingTemplate will only apply to that ThingTemplate and any child ThingTemplates
Run Time Instance, Design Time Instance, and Visibility Instance permissions on a ThingTemplate will be applied to all Things that use this ThingTemplate
Run Time, Design Time, and Visibility permissions on a Thing will override any instance permissions set on the ThingTemplate level
Let me know if it helps or you need further clarification.
