Why the import from the file is not available on my Thingworx Composer? None of the tutorials working?
Jarmo, what sort of ThingWorx instance is this? Is it an academic instance or you have it installed locally? What sort of user are you logging in with and not seeing the import option?
If this is an academic instance Import/Export Menu isn't available. For that you may want to download the ThingWorx trial edition and install it locally.
Yeah, it is academic. Thank you for the answer.
