With QueryDataTableEntries service to compare between dates
SaranKarthick
I'm working on a service which gets two dates as input(Start and End dates) and returns the entries for which the dates in a particular column lies within the input range as an infotable.
I have used a query with the "BETWEEN" type filter.
The code i used is:
var query = {
  "filters": {
    "fieldName": "LoanStartDate",
    "type": "BETWEEN",
    "from": 1483122600000,
    "to": 1517337000000
var params = {
  maxItems: undefined /* NUMBER */,
  values: ApprovedLoanableAssets /* INFOTABLE*/,
  query: query /* QUERY */,
  source: me.name /* STRING */,
  tags: "Keysight-Customer:"+CustomerID /* TAGS */
//result: INFOTABLE
var result = Things[CustomerID+"-LoanPoolAssetDetailDT"].QueryDataTableEntries(params);
The output is:
The output is without any entries.Yes, i have checked if there are no entries to be shown, but i'm sure that it consists of atleast one entry which coincides with the query. Can you point where i went wrong. Thanks in advance.
2 REPLIES 2
You had filled a lot of parameters, you are 100% sure that the other parameters are ok? I mean:
  • values: ApprovedLoanableAssets --> Which it's the content of this object?
  • source: me.name --> You are sure the DataTable Entries has source filled
  • tags: "Keysight..." --> You are sure entries are correctly tagged?
What I would do it's query for one condition ( source, or tags, or values ) and keep adding the others until you don't get anything.
Sorry for the late reply. The source parameter was wrong. Now its working fine. Thanks for ur suggestion.
