I have come across a new issue with Workflow.
After exporting it with other Thingworx entities in a single Git Extension,the "Workflows" Thing in the composer has become non-editable.
I checked its xml configuration and has found it has a new property added to it as "aspect.isExtension="true", after the bundling it with the Extension.
It also has a property as "isAllowOverride="false". I also tried to change it to TRUE so that I can import an editable "Workflows" Thing but no luck.
I tried changing and removing these properties and import manually but still not able to make the Thing editable.
Any suggestions/ comments how to resolve this?
