Is it possible to add new state in already existing state definition using service?
I wanted to add a new style that I am creating using service in a new state that I am adding using service.
Thanks in advance,
Shalini V.
You cannot add it via services but you can through a rest call. When you add a new state in the composer manually, look up the request that goes through in the network tab of the dev tools and mimic it in your rest call
