How can we add dynamic value bind and set widget based on that with thingworx advance grid ?
Hello @VS_10112707 ,
As i can understand from your query, you wanted to bind dynamic data to AdvanceGrid widget. To achieve, you can write a service which returns infotable as output and bind that to data field of AdvanceGrid.
Please refer the attached article for the further info:
https://www.ptc.com/en/support/article/CS318198
Bhawna
Bhawna
