autofocus text field widget no longer works from 9.1 to 9.3.2
JO_9930585
11-Garnet
The text field widget used to have an auto focus (built into it I assume?). This was how it worked in 9.1.1. We recently upgraded to 9.3.2 and it no longer auto focuses. We looked for a way to resolve this but cannot seem to find one. How do I get the autofocus to work again for this widget? We have popups that need this functionality.
3 REPLIES 3
1. Discussion - "Text Field widget not focusing": https://community.ptc.com/t5/ThingWorx-Developers/Text-Field-widget-not-focusing/td-p/676141
2. Article - "There is no indication that the focus is on the Text Field widget in ThingWorx": https://www.ptc.com/en/support/article/CS327895
The css in these solutions does not fix the issue unfortunately. Also, the first link is for a browser upgrade which doesn't apply to this. The seconds one states "When the user clicks on a Text Field widget, there is no indication that the focus is on the Text Field widget". This is also not the issue I am having. Selecting the text box works fine. The issue is that one must now select it to be focused. Thanks though.
wcui
(To:JO_9930585)
hi Jo_9930585
Can you share demo mashup so we can understand this issue better?
