combo box multi select
svisveswaraiya
How does the multi select option work in Combo box of ThingWorx 8.2?
I have an sql query where I have given input of combo box data. I have checked the multi select but it does'nt work. Should I write any script to make it work?
Shalini V
3 REPLIES 3
Hi @svisveswaraiya
Without a better understanding of your use case, here are a couple of articles that may help to answer your question:
Unable to select multiple items on List widget in List view even when MultiSelect property is enabled in ThingWorx
Is it possible to make Drop down list multi selectable in ThingWorx 8.2
--Sharon
slangley
23-Emerald II
(To:slangley)
Hi @svisveswaraiya
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
Are you binding the value and display field to a service? This is an example from a similar multi select list. Hope it helps
