confirmation dialogue box
AP_9587236
Any properties available to customise/styling confirmation dialogue box?
PaiChung
22-Sapphire I
(To:AP_9587236)
I don't know, you could do a custom pop-up mashup? You might be able to find the css as well and customize that way.
8 REPLIES 8
PaiChung
22-Sapphire I
(To:AP_9587236)
Okay thanks
slangley
(To:AP_9587236)
Hi @AP_9587236.
Where is the dialog box coming from? Please provide more details around your design.
--Sharon
For logout button extension, there is a property "Confirmation Required". If we clicked button, popup will come with two options 'yes' or 'no'. You can try this for normal button widgets also. @slangley
slangley
(To:AP_9587236)
Hi @AP_9587236.
Which version of ThingWorx are you running and which widget are you using?  Is it one of the legacy widgets?
--Sharon
Version is 8.4.4. Widget is "Button". How to check whether the widget is legacy or not in composer?
slangley
(To:AP_9587236)
Hi @AP_9587236
Here's a list of the legacy widgets.  However, I can't recall if any of these would have been considered legacy in your release, since it's no longer supported.
I recommend that you upgrade to a supported version of the product--ThingWorx 9.0 or above.  ThingWorx 8.5 is still currently supported but support ends next month.
--Sharon
slangley
(To:slangley)
Hi @AP_9587236
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
