hello everyone
Iam having an issue with Dashboard widget responsiveness functionality, it works well when using gadgets without changing width of gadget, but if the size of the gadget is smaller than the default size of the columns selected(rows * columns); it will leave white space in the shrunken space.
for example, if i create a 1 * 1 gadget which has a default size of 240 * 240 and change it's size to 200 * 200, the difference in size which is 40 * 40 will be filled with white space.
the problem with this is that Thingworx uses fixed size for each row and column(240px per row or column) with out calculating the total width of gadgets in the row; which will reduce the number of gadgets in row if the actual gadget size is smaller than default.
I tried changing the width of the div containing the gadget using custom CSS but that didn't solve the issue.
is there a way to fix this issue?
Hi @prajendra.
After researching further, it's recommended that you post this request on the ThingWorx Ideas board. This will allow others to vote for it, which will increase the possibility that it will be considered for a future release.
--Sharon
Hi @prajendra.
Please advise the version of ThingWorx you're running. Can you also provide screenshots of what you're seeing?
--Sharon
Hi @prajendra.
--Sharon
Hi @prajendra.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Thank you for your participation in our community!
--Sharon
