Whenever a datashape is created from a sql query it becomes static. If I make any changes in the query like adding a new column or removing I have to again create a new datashape. But is it possible that the datashape becomes dynamic and adjusts according to the query whenever it is changed?
Shalini V.
The output of a service as defined can only have one DataShape (only System Services can have "Dynamic DataShapes" to be shown on Mashups - for instance QueryImplementingThings or GetProperties services), but you can always output any amount of columns (dynamic) out of a services ignoring the defined DataShape.
Hi CarlesColl,
Thanks for your quick response.
Do you mean I can output any number of columns and create datashape from the respective output?
You can output any number of columns yes, you don't need to create a specific DataShape if it's dynamic.
If one of the responses from @CarlesColl answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
