diffviewer widget is deleted in latest thingworx version. Any Alternatives?
twxadmin
diffviewer widget was very useful in gitbackup extension to see differences between different commits. Now it's not available. do we have any alternate approach/widgets to see diffs between commits ?
Hi TWXadmin,
Referring to the gitbackup extension, as its (main) developer, I'm unclear why you report the diff widget is not available.
I'm running the extension in my 9.3.8 instance and I can see the widget in Mashup Builder  - also it works well in the GitBackup.Main.Mashup
As a reminder to others, even if in this situation we speak about a widget that is part of the extension and not meant for custom use, if you have any issues with the GitBackup extension, please report them here: https://github.com/PTCInc/thingworx-gitbackup-extension/issues as it's not a PTC Supported product.
I didn't know about the diffviewer widget on gitbackup ....
I use API from diffchecker.com
created a mashup calling API with ContentLoaderFunctions.PostText , you can compare two text with colors ... it's great !
I use compare differencies on entities on different thingwors instances
Thank you @iguerra . Its interesting. I will give it a try.
Hi TWXadmin,
Thank you @VladimirRosu . I realized late that diffviewer was part of package of GitBackup extension. I imported diffviewer from your extension package and it works like charm now.
