edit infotable datashape do not apply changes
aziliotto
i need to change a property definition on a Thing.
The thing is Called TT and is an instance of the template A that has a property defined like this:
Property Name: info
Property DataShape: DB
DB has inside 2 other infotable of the type DB_row.
I added 2 columns to the datashape definition DB_row. saved the datashape.
I restarted the Thing TT to apply changes but when i browse  the property info i didn't see the 2 new columns.
How can i fix this issue ?
slangley
23-Emerald II
(To:aziliotto)
Hi @aziliotto.
Please export the entities (thing, thing template, data shape) and attach them here and we will take a look.  Also, which version of ThingWorx are you running?
Regards.
--Sharon
PaiChung
22-Sapphire I
(To:aziliotto)
Try a full refresh of composer, it may still be showing a cached definition.
aziliotto
(To:PaiChung)
Already tried but did not work.
The solution was:
1.create a new infotable property defined with the edited datashape.
2.check that new colums were as expected.
3.make a service that copy each row of inner infotable to this new property.
4.copy this new property to the old one as me.OldPropertyInfotable = me.NewPropertyInfotable.
