error in licensing thingworx
SOLVED
asn
Level 6
I am using ThingWorx 8.3.1.
ThingWorx was working fine on my windows 10 system as well as a cloud based windows server, while suddenly the license in the "ThingworxPlatform" folder changed from "successful_license_capability_response" to "ignored_license_capability_response" on both these windows systems.
Below is my application log.
2018-12-05 16:06:04.507+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: main] Subsystem LicensingSubsystem is starting
2018-12-05 16:06:04.507+0530 [L: INFO] [O: c.t.s.s.Subsystem] [I: ] [U: SuperUser] [S: ] [T: main] Starting Subsystem [LicensingSubsystem]
2018-12-05 16:06:40.132+0530 [L: ERROR] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [T: main] Unable to process capability response because Storage anchor break found.
2018-12-05 16:07:12.311+0530 [L: ERROR] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [T: main] Unable to process capability response because Storage anchor break found.
2018-12-05 16:07:44.817+0530 [L: ERROR] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [T: main] Unable to process capability response because Storage anchor break found.
2018-12-05 16:08:17.765+0530 [L: ERROR] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [T: main] Unable to process capability response because Storage anchor break found.
2018-12-05 16:08:17.768+0530 [L: ERROR] [O: c.t.s.s.l.LicensingStateMachine] [I: ] [U: SuperUser] [S: ] [T: main] Unable to fetch license file with device id XXXX
2018-12-05 16:08:17.806+0530 [L: ERROR] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [T: main] Unable to process capability response because Storage anchor break found.
2018-12-05 16:08:17.817+0530 [L: INFO] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [T: main] Unable to read trial license file. Attempting to load as Paid license
2018-12-05 16:08:17.847+0530 [L: ERROR] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [T: main] [message: Storage anchor break found.]
2018-12-05 16:08:17.847+0530 [L: ERROR] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [T: main] ====================================================================
2018-12-05 16:08:17.847+0530 [L: ERROR] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [T: main] License file missing. It's expected at path : C:\ThingworxPlatform\license.bin
2018-12-05 16:08:17.847+0530 [L: WARN] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: main] Shutting down the Platform.
What could be the possible reason?
I have tried re-downloading the license from the license management portal and placing it in the ThingworxPlatform folder by renaming it as "license_capability_response".
However, the same error occurs.
Thanks.
Re: error in licensing thingworx
Hi @asn.
The solution to the final licensing issue was to create a service account (Windows) with Administrator rights and reconfigure the Tomcat service to run under this account.
For the original issue, it would be helpful if you would mark the appropriate response as the Accepted Solution for the benefit of others who may experience similar issues.
--Sharon
Try the solution from the article CS281516
ThingWorx 8.1 licensing failed with message "Unable to process capability response: Storage anchor b...
Best regards,
Raluca Edu
Hi @raluca_edu,
As I am working in a secure restricted environment, I do not have the permissions to create a new user as explained in the article you suggested. Is there any other way around this?
Unfortunately, I don't know another solution, but maybe someone from Community has another solution.
Best regards,
Raluca Edu
Hi @asn.
This is the same issue already reported for your company per this community post.  I have reached out to the License Management team to get this issue resolved.
As soon as I have received confirmation that the issue has been corrected, I will let you know.
--Sharon
Hi @asn.
I have worked with the License Mgmt team to address this issue.
If you are using a connected scenario (Support login information is included in \ThingworxPlatform\platform-settings.json), you should be able to simply restart Tomcat in order for the license file to update.  If you are manually updating the license, follow these instructions:
  1. Login to the License Management portal
  2. Enter your device ID and click Retrieve
  3. Download the license and place it in the \ThingworxPlatform folder
  4. Move the existing license_capability_response.bin file to another location
  5. Rename your newly downloaded license file to license_capability_response.bin
  6. Restart Tomcat
If you still have issues, please let us know.
--Sharon
If my response has answered your question, please mark it as the Accepted Solution, for the benefit of others who may have the same question.
Hi @slangley,
Thanks a lot for the support.
The ThingWorx server on the AWS instance is working fine now.
However, in my local windows 10 system I am still facing the issue.
PFB the application logs -
2018-12-06 09:00:58.839+0530 [L: INFO] [O: c.t.s.s.Subsystem] [I: ] [U: SuperUser] [S: ] [T: main] Starting Subsystem [LicensingSubsystem]
2018-12-06 09:01:34.906+0530 [L: ERROR] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [T: main] Unable to process capability response because Storage anchor break found.
2018-12-06 09:02:10.362+0530 [L: ERROR] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [T: main] Unable to process capability response because Storage anchor break found.
2018-12-06 09:02:49.453+0530 [L: ERROR] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [T: main] Unable to process capability response because Storage anchor break found.
2018-12-06 09:03:28.693+0530 [L: ERROR] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [T: main] Unable to process capability response because Storage anchor break found.
2018-12-06 09:03:28.695+0530 [L: ERROR] [O: c.t.s.s.l.LicensingStateMachine] [I: ] [U: SuperUser] [S: ] [T: main] Unable to fetch license file with device id XXXX
2018-12-06 09:03:28.755+0530 [L: ERROR] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [T: main] Unable to process capability response because Storage anchor break found.
2018-12-06 09:03:28.766+0530 [L: INFO] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [T: main] Unable to read trial license file. Attempting to load as Paid license
2018-12-06 09:03:28.797+0530 [L: ERROR] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [T: main] [message: Storage anchor break found.]
2018-12-06 09:03:28.797+0530 [L: ERROR] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [T: main] ====================================================================
2018-12-06 09:03:28.797+0530 [L: ERROR] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [T: main] License file missing. It's expected at path : C:\ThingworxPlatform\license.bin
2018-12-06 09:03:28.797+0530 [L: WARN] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: main] Shutting down the Platform.
I tried the steps you mentioned in your previous reply but the error still persists.
Hi @asn.
I see this in the log snippet you provided:
Did you replace the actual Device ID with XXXX to mask it for this post?  If so, just make sure you are generating separate license files for each environment.  The Device ID is unique across ThingWorx implementations.
I also see this in the log snippet:
The file name in the log "license.bin" is a carry-over from previous versions of ThingWorx.  You will need to validate the file you downloaded was renamed to license_capability_response.bin.  It will not work if renamed to license.bin.
Please let me know if you continue to have issues.  If so, we will need to open a case to review in greater detail.
--Sharon
Yes I did replace the actual device id with XXX to mask it. . And I did download separate license for this device ID and replaced it as "license_capability_response.bin" in the ThingworxPlatform folder .
However the same issue occurs.
Maybe try the following :
  1. Stop Tomcat
  2. Delete the content of C:\ProgramData\ptc_p (take a backup before)
  3. Restart Tomcat
