Is it possible to download the data shape headers in a excel using link widget?
Shalini V.
You can do a few different things.
1. Use a service to derive the headers of a DataShape and that can be output as a csv file
2. Use a Service to create an empty infotable with the datashape put it on a DataExport widget and that will export it as CSV
3. Direct URL call to retrieve the definition, you could get it as xml or json
If the solution provided by @PaiChung answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
