export nested infotable in excel
cbaurand
Is it possible to export nested infotable in excel:
I have a infotable which contains an other infotable. I'm struggling with displaying the data from the nested infotable.
InfoTable A : {
address: { number: "2", road: "pin"}
I can easily display name by referencing it with {{name}} in excel template but i'm not able to reference number and road. Any idea ?
Thanks.
cbaurand
(To:anarwal)
In fact, the response is no because i just created an infotable without nested infotable and with all data i needed. Not really beautiful but it works.
6 REPLIES 6
PaiChung
22-Sapphire I
(To:cbaurand)
I've never really tried this, but you may have to generate two exports, which would mean manual combine afterwards.
cbaurand
(To:PaiChung)
Finally, i use another  way to solve my problem. Thanks.
anarwal
(To:cbaurand)
Hi @cbaurand ,could you share your way to export nested tables it will help in future reference when other community member might face this issue.
cbaurand
(To:anarwal)
slangley
(To:cbaurand)
Hi @cbaurand.
Since you found a solution to your issue, would you please mark your last response as the Accepted Solution for the benefit of others on the community?
Regards.
--Sharon
slangley
(To:cbaurand)
Hi @cbaurand.
If you feel your question was answered, please mark the previous response as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
