Jul 17, 2017 4:53 AM UTC
forget administrator password
I forgot my Thingworx administrator password, How can I do? I don't want to rebuild my database.
Jul 17, 2017 5:11 AM UTC
ling zhou​,
Are you running PostgreSQL ThingWorx? For PostgreSQL you could try with:
1. Using pgAdmin III or psql, connect to the ThingWorx database with the ThingWorx DB user password .If necessary, the database username and password can be retrieved from the platform-settings.json file located in the /ThingworxPlatform directory on the ThingWorx server.
2. Run the following SQL statement:
UPDATE user_model SET "passwordHash" = '100000:ecbad5a6dc172f92cddd4743e6b4877724e0c675e6e2fc1c780ab62a2350f115acdbd3c6c582afd297a4c77fb5420520e3f36c2c5e12dbfc5fc9c4f3fc2d616d:6fd6785de35b500fb633ab13be4207dead6c26f922b32610c135f446fea2d4abbce57be9058457cddd4e3944fcf42b804c29dc8939a3c29ca6ac64001d0a982c' WHERE name = 'Administrator';
In my example, the password will be "admin"
But this is just for some urgent case and you have no other choice. Directly changing database is not advised.
Br,
Anna
Nov 8, 2017 10:13 AM UTC
Hi Anna,
I tried updating my Postgre with the SQl statement you mentioned and got it updated. However when I type admin as the password, it still doesn't work. Can you please confirm the password again?
20-Turquoise
Jul 17, 2017 5:31 PM UTC
Do you have an application key associated with the Administrator?
How to reset Password for users using Administrator Appkey
