format of JSON for PUT method of geo type property
pmishra-4
Hi, I want to post lat long and height to loc property (field type geo). I am trying this
URL :-localhost:8080/Thingworx/Things/liveVehicle/Properties/loc
HEADERS :-
rest_thing_api:e3c27605-2c66-40d6-b914-4a6bf57c1f33
Userid:Administrator
Password:admin
Content-Type:application/json
JSON
      "lon": "104.211",
      "lat": "10220.030",
      "height": "0"
Please suggest correct format of jSON?
20 REPLIES 20
Hello Prabhat,
I can show you one trick. In the Composer go to your Thing with Location property. You can set the value manually:
In meanwhile go to the browser Developer Tools (F12 in Chrome) and then to the Network Tab.
Come back to the Composer and click Done to set dummy value.
Every change like this is also a REST PUT request. So you can take a look on the Headers and Request Payload to see how it should look like.
I hope it helps.
Adam
Its showing error :- JSON Content for loc Was Not ValidProperties
It's showing JSON Content for loc Was Not ValidProperties
My bad, I forgot to tell you that property names must be also in quotes just like this:
    "location": {
        "latitude": 50,
        "longitude": 50,
        "elevation": 50
Remember that JSON format require property names in quotes.
Adam
Thanks, It worked out.
So the correct format of JSON will be ( for other buddies who might face same same problem)
{ "loc": {"latitude": "0.1111", "longitude": "0.22222", "elevation": "033333", "units": "WGS84"}}
Hi. status Code is saying 200.
But value is not reflecting in property.
I tested your values and I am receiving 406. Probably because "elevation": "033333" ​ is not acceptable.
This is my JSON:
    "location": {
        "latitude": 0.1111,
        "longitude": 0.2222,
        "elevation": 0.3333,
        "units": "WGS84"
Remember also to setup proper REST Headers:
appKey/Authorization
Accept -> application/json
ContentType -> application/json.
You also check for ThingWorx logs to see if there is more information there.
Adam
One more thing is that if you will save your thing, after setting up some values you will lost it.
To keep it 'forever' you need to tag you property as Persistent.
Adam
KSM
(To:A_Macierzynski)
Hi Adam,
Could you please show e the entire code of format, because am also posting values in the form of json
A_Macierzynski
(To:KSM)
What I mean is just change your param Type from JSON to String. Then you can use Event to pars it to the JSON by using JSON.parse(yourStringVal) to have a JSON.
I am not saying that it will work, but I had similar problem with Service and JSON input so it can be the same issue.
Adam
KSM
(To:A_Macierzynski)
Thanks for Quick Reply,
My requirement is some little bit different, I need to write the script code where it will take the current property values and that values need to post to REST API in a specific format of a json.
I am getting confusing how should and where to  include that json format in the script code.
A_Macierzynski
(To:KSM)
Now I am also confused. Can you described whole workflow one more time? Where is the input, what should be the output?
Adam
KSM
(To:A_Macierzynski)
  "jsonData": {
    "ConnectionID": "F-105",
    "current": 320.77,
    "voltage": 640,
    "KW": 480.23,
    "Powerfactor": 80.85,
    "timestamp": 1511793691000
this is the format of json my REST API will accept in payload or body area. the key values of json should be take from the property values of the thing. I need to code that in script area so that it will take the values from the current values of the property and the format of json should look like this should be posted to my REST API URL. output should show status of 200 ok thats it.
A_Macierzynski
(To:KSM)
var jsomData = {
  "jsonData": {
    "ConnectionID": me.connectionID,
    "current": 320.77,
    "voltage": 640,
    "KW": 480.23,
var params = {
proxyScheme: undefined /* STRING */,
headers: undefined /* JSON */,
ignoreSSLErrors: undefined /* BOOLEAN */,
useNTLM: undefined /* BOOLEAN */,
workstation: undefined /* STRING */,
useProxy: undefined /* BOOLEAN */,
withCookies: undefined /* BOOLEAN */,
proxyHost: undefined /* STRING */,
url: undefined /* STRING */,
content: jsonData /* JSON */,
timeout: undefined /* NUMBER */,
proxyPort: undefined /* INTEGER */,
password: undefined /* STRING */,
domain: undefined /* STRING */,
username: undefined /* STRING */
// result: JSON
var result = Resources["ContentLoaderFunctions"].PutJSON(params);
You can try with PutJSON method under Resources -> ContentLoaderFunctions.
Instead of hardcoded values you can refer to your property value like under the ConnectionID.
KSM
(To:A_Macierzynski)
Thanks Adam,
I will try this code.
KSM
(To:A_Macierzynski)
Thanks Adam that code is working fine and posting successfully.
A_Macierzynski
(To:KSM)
Great to here that.
Adam
KSM
(To:A_Macierzynski)
I tested your values and I am receiving 406. Probably because "elevation": "033333" is not acceptable.
This is my JSON:
    "location": {
        "latitude": 0.1111,
        "units": "WGS84"
Adam
Hi  just I want to try like the above code Could you please help me out
A_Macierzynski
(To:KSM)
Ok. What you need to know is that I used 3rd party application to send this REST PUT call. You want to send this REST inside ThingWorx in Service? What is your goal?
KSM
(To:A_Macierzynski)
yes exactly I dont want to use any third party application .
