Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
I use 30 days hosted trial, google map widget could not load normally in View Mashup, Error Message like "Oops! Something went worng... See the JavaScript console for technical details.". How could I get this right?
Hi Sandra, have you check the browser's developer console for more detail or may be the ApplicationLog from ThingWorx? Was this working when you first created the instance?
Could you access to Google map seperately from your browser?
For some Chinese customers, it may not be accessible for Google Map.
Baidu map will be used instead in such case.
Br,
Anna
Hi Anna An, I could access to Google map from browser.
Hi Sushant, Thank you for your suggestion. I have check application log, but it seems no error message about this.
Did you also check the Developer's console?
Sandra, where do you find the google map widget when you create your mashup?
Hi Xinyan, I get google map widget from mashup -> widgets-> category (filter)-> key in google map, to get goole map widget.
Hi Sushant, show log for view mashup is as below:
Sorry if i was not clear enough in my last response, I meant the web browser's own developer console for e.g. if you'd press F12 in chrome you should be able to view this console and then you will have to refresh the page once. Please check if there are any errors/warnings there.
You may want to take a look at this thread Google Maps no longer displaying (Error - 'Oops! Something went wrong')
It may be missing Google API Key in metadata.xml file.
Hi Sushant & Varathan, thank you very much, from the browser developer console, it seems the Google API key problem, I will find how to put Google API key in metadata.xml.
How could I extract metadata.xml and modify it ? Extension just could be imported or viewed from composer.
It's right to download google widget extension from makerplace, and modify metadata.xml, and import extension?
Hi Sandra, yes it OK to do that to update the key. In fact you can refer to this article guiding you on how to update the key in the metadata.xml API Keys and the Google Map Widget in ThingWorx
Hope this'd help.
Hi Sushant, thank you for your help, google map can be viewed normally.
Glad it helped
