Is it possible to highlight the grid cell when trying to edit it. I have enabled the grideditable option in advanced grid and wanted to highlight the cell which the user is trying to edit (Either change color till he saves or make the border thick while the cursor is on the cell).
Thanks in advance,
Shalini V.
Hi @svisveswaraiya ,
Please check below article and see if the workaround suggested in it helps
https://www.ptc.com/en/support/article/CS280979
Toolika Dixit
Beyond my skill level but I believe this is possible by adding a CSS class
Toolika Dixit
Hi @svisveswaraiya.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
