Hi, i was thingworx model tutorial. how do u get to this page on thingworx composer?
Hi @hujingrui
Sorry for delay in answering.
You will have the AnalyticsServer_TrainingThing if you have installed a ThingWorx Analytics Server and if it successfully connect to ThingWorx Platform.
So the first thing is to:
- confirm you have a ThingWorx Analytics Server installed.
- check that the connection to ThingWorx platform are correct in <ThingWorxAnalyticsServer>/config/system-environment-variables.properties file. Mostly check the properties thingworx.hostname thingworx.port and thingworx.application.key (if in 8.3.x)
- start ThingWorx Analytics Server, if those things doe not get created, please provide/check the <ThingWorxAnalyticsServer>/data/logs folder
Hope this helps
Kind regards
Christophe
it says
In ThingWorx Composer, search for <Analytics_Server>_TrainingThing
Under Services, select CreateJob , click Test.
But i cannot seem to find Analytics_Server_TrainingThing or even AnalyticsServer_TrainingThing.
Hi @hujingrui
Hope this helps
Kind regards
Christophe
