how to bind image widget with selected item in advanced grid widget
tlichtenberger-
Hey there,
I have made an advanced grid which holds a few aircrafts plus some informations for each one.
I have also managed to visualize some data with other widgets from the aircraft which is currently selected.
It all works fine except for the image-widgets. Each Aircraft-Thing has a certain image stored which I want to show when the Aircraft is selected in the advanced grid.
If I execute the mashup, there will only be this symbol shown instead of the image:
In the following, you can see my searchGridService, which gives me the values for the aircraft currently selected:
var params1 = {
  infoTableName : "InfoTable",
  dataShapeName : "FullGrid_datashape"
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(InfoTableDataShape)
var result1 = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params1);
// result: INFOTABLE dataShape: RootEntityList
var tmpInfoTable = ThingTemplates["AC_template"].GetImplementingThingsWithData();
var tableLength = tmpInfoTable.getRowCount();
var MyObject = new Object();
for (var x = 0; x < tableLength; x++) {
    MyObject.datDate = tmpInfoTable.getRow(x).datDate;
    MyObject.txtFrom = tmpInfoTable.getRow(x).txtFrom;
    MyObject.txtTo =tmpInfoTable.getRow(x).txtTo;
    MyObject.numFlightTimeDecimal =tmpInfoTable.getRow(x).numFlightTimeDecimal;
    MyObject.numSeatCapacity =tmpInfoTable.getRow(x).numSeatCapacity;
    MyObject.numLoad =tmpInfoTable.getRow(x).numLoad;
    MyObject.numDirt =tmpInfoTable.getRow(x).numDirt;
    MyObject.numTotalFlightTime =tmpInfoTable.getRow(x).numTotalFlightTime;
    MyObject.numCummulatedDirt =tmpInfoTable.getRow(x).numCummulatedDirt;
    MyObject.txtAC_tag = tmpInfoTable.getRow(x).txtAC_tag;
    MyObject.txtAC_type =tmpInfoTable.getRow(x).txtAC_type;
    MyObject.txtAirportCodeFrom =tmpInfoTable.getRow(x).txtAirportCodeFrom;
    MyObject.locLocationGPSFrom =tmpInfoTable.getRow(x).locLocationGPSFrom;
    MyObject.locLocationGPSTo =tmpInfoTable.getRow(x).locLocationGPSTo;
    MyObject.txtAirportCodeTo =tmpInfoTable.getRow(x).txtAirportCodeTo;
    MyObject.txtFlight =tmpInfoTable.getRow(x).txtFlight;
    MyObject.numAnalyticalDirt =tmpInfoTable.getRow(x).numAnalyticalDirt;
    MyObject.numAnalyticalDirtCummu =tmpInfoTable.getRow(x).numAnalyticalDirtCummu;
    MyObject.imageSeat = tmpInfoTable.getRow(x).imageSeat;  <-- THERE IS THE IMAGE ATTRIBUTE
    MyObject.numToilets =tmpInfoTable.getRow(x).numToilets;
    MyObject.txtMSN = tmpInfoTable.getRow(x).txtMSN;
    MyObject.txtAirline = tmpInfoTable.getRow(x).txtAirline;
    MyObject.datDatetoday = tmpInfoTable.getRow(x).datDatetoday;
    MyObject.txtActualLocation = tmpInfoTable.getRow(x).txtActualLocation;
    MyObject.numProbability = tmpInfoTable.getRow(x).numProbability;
  result1.AddRow(MyObject);
var params = {
  t: result1 /* INFOTABLE */,
  query: query /* QUERY */
var result = Resources["InfoTableFunctions"].Query(params);
In the mashup, I have binded the image-Widget as follows:
If you need further information, please comment!
Thank you so much for your help.
Best wishes,
Theresa
0 REPLIES 0
