I need to create table in below format show two products compatibility. So i am not getting which widgets will help to create table with below requirements
You can use the Grid widget, if you are lookign for dynamic rows and column size. look for configuring the grid using JSON configuration.
Check this: LINK
Hello @SS_2318,
It looks like you have a response from a community member. If it helped you solve your issue please mark the reply as the Accepted Solution.
Community Moderation Team.
