how to fix error related to 'thingworx:temperature-thing:jar' in temperature-thing project
festes
I'm trying to connect Thingworx to Raspberry Pi using temperature-thing example with Am2302 sensor.
Thingworx-common jar file has been installed manually, but running 'mvn package' gave the following error:
C:\Users\Lipi.Malladi\Downloads\temperature-thing\temperature-thing>mvn package
[INFO] Scanning for projects...
[INFO]
[INFO] ------------------------------------------------------------------------
[INFO] Building temperature-thing 1.0-SNAPSHOT
[WARNING] The POM for com.thingworxs:thingworx-common:jar:6.0.2 is missing, no dependency information available
[INFO] BUILD FAILURE
[INFO] Total time: 0.643 s
[INFO] Finished at: 2017-07-10T15:10:55-05:00
[INFO] Final Memory: 6M/15M
[ERROR] Failed to execute goal on project temperature-thing: Could not resolve dependencies for project com.ptcmanaged.thingworx:temperature-thing:jar:1.0-SNAPSHOT: Failure to find com.thingworxs:thingworx-common:jar:6.0.2 in https://repo.maven.apache.org/maven2 was cached in the local repository, resolution will not be reattempted until the update interval of central has elapsed or updates are forced -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
I have updated the link in pom file to: http://maker01.cloud.thingworx.com/mvnrepo
Please let me know how this error could be resolved. Thanks
supandey
(To:festes)
Hi Fred, which Edge SDK are you attempting to setup? Seems like the class path configuration is incorrect
festes
(To:supandey)
Hi Sushant, I am trying to setup SDK version 1.0.0.38
