how to give a number with percentage % in datatable
lyang1
2-Explorer
how to give a number with percentage % in datatable?
Set Grid's Number Column format and add it a %, here you have a sample:
lyang1
2-Explorer
(To:CarlesColl)
I had try like this ,but it didt work. The tip is only“use the "0"or".".
I was able to set it with 6.5.13, but maybe with newer versions you can't. If you need to do it, you may play around with XML mashup version ( I tried it and it works ), but you must know that this isn't supported by TW.
Best Regards,
Carles.
lyang1
2-Explorer
(To:CarlesColl)
Thank  U very much! I'll try in the lower version and the XML!
