how to hide the "show/hide log" bar in a mashup tests ?
pjoly
hello
I cannot find where to disable the top bar when performing some tests from the composer (to get same screen sizing as at runtime)  :
Is it possible ?
When I load the mashup from "organization" login I don't have this bar.
Pascal
Aanjan
(To:pjoly)
Pascal, as James noted, the 'fromBuilder' part on the URL loads the 'show/hide log' bar. Ctrl+alt+F9 is the shortcut to show/hide the actual bar itself.
3 REPLIES 3
jamesm1
(To:pjoly)
You have to get rid of the fromBuilder url parameter and then refresh (or load independently). I don't believe there is a way to disable it by default when  you load the mashup from the "view" button in the builder, because it automatically adds the fromBuilder parameter to the url.
Aanjan
(To:pjoly)
pjoly
(To:pjoly)
CTRL+ALT+F9 works fine !
