how to import svg image to media
YS_10134308
11-Garnet
Hello ,
I have tried this solution also , still not working - Solved: Re: Thingworx 8.5.4 not able to import svg-xml med... - PTC Community
I am using thingworx 9.
It is giving me the error - invalid length
Found an old article - "Is it possible to use SVG images in Thingworx": https://www.ptc.com/en/support/article/CS203748
Hii,
VladimirN
https://www.ptc.com/en/support/article/CS203748 according to this link it says that SVG images are not supported in thingworx , is there any way by which we can upload SVG images in media.
slangley
(To:YS_10134308)
Hi @YS_10134308.
An alternative would be to convert the SVG to a different format.  If you're inclined to do so, you could also write your own extension.
--Sharon
