hi experts
I wanna load image in infotable. There are 4 field names in datashape.
one of the four is imagelink type.
How can I load an image on infotable?
Hi @JackEom
In the DataShape you can choose to implement
If you try to implement it programmatically, you can also create a new Property on a Thing with the InfoTable Type and a DataShape that contains both (Image + ImageLink) to check the differences before coding it.
Hi @JackEom
Thank you mneumann!
Your advice is very helpful.
