how to make a gadget in the dashboard 'clickable' to set a session parameter
GM_9528891
11-Garnet
Hello everyone !! Is there a way to set a gadget added to a dashboard as a session parameter? The event that would change this parameter would be a double click on it.
Specifically, I would like to be able to make a gadget in the dashboard 'clickable' to set a session parameter .. my final goal would be to bind data at runtime in the gadget.
if the question is unclear I try to add more info .. thanks
1 ACCEPTED SOLUTION
PaiChung
22-Sapphire I
(To:GM_9528891)
Sounds like you want to assign a parameter 'dynamically' to be displayed in the gadget?
I think standard gadget setup would have you pick the value and that gets locked in on the gadget as a mashup parameter.
After that is locked in, in the gadget you can use a service to do what you need with the value.
The only way to change a gadget value after 'instantiated' on a dashboard would be to use session parameters.
PaiChung
22-Sapphire I
(To:GM_9528891)
slangley
23-Emerald II
(To:GM_9528891)
Hi @GM_9528891.
If you feel the previous response was helpful, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
