The above is the existing info table now i need to group by based upon the Hour as shown below
Kindly help me on this
You just need to use InfoTable.Aggregate snippet.
var result = Resources["InfoTableFunctions"].Aggregate({
t: infotableVar,
columns: "Count",
aggregates: "SUM",
groupByColumns: "ID,Hour"
I am unable to use aggregation for sum or max or min value calculations.
Here is my code:
var params = {
path: "test_aggrigation.csv" /* STRING */,
columnMappings: undefined /* STRING */,
hasHeader: undefined /* BOOLEAN */,
longitudeField: undefined /* NUMBER */,
dateFormat: undefined /* STRING */,
fileRepository: "FileStorageThing" /* THINGNAME */,
latitudeField: undefined /* NUMBER */,
fieldDelimiter: undefined /* STRING */,
stringDelimiter: undefined /* STRING */,
dataShape: "aggrigateShape" /* DATASHAPENAME */
// result: INFOTABLE
var data = Resources["CSVParserFunctions"].ReadCSVFile(params);
logger.warn(data);
//Aggregate code start from here..
t: data,
columns: "temp_min",
aggregates: "SUM",
groupByColumns: "temp_max,date"
ERROR Code:
Error executing service calculateMin. Message :: java.lang.String cannot be cast to java.lang.Number - See Script Error Log for more details.
Can you please help me on this?
Regards
Vikas
temp_min column it's a String or a Number?
But anyway, ReadCSVFunctions shouldn't work, as you are missing some required parameters like columnMappings, focus first on reading correctly the csv file, and the temp_min columns as a Number and then aggregate
Hi Carles,
I am able to read csv file with above code. "temp_min" is number!
HERE is my code:
var params = {
hasHeader: "false" /* BOOLEAN */,
result1 = Resources["CSVParserFunctions"].ReadCSVFile(params);
var params1 = {
maxItems: undefined /* NUMBER */
var result = Things["TestDataTable"].GetDataTableEntries(params1);
var newID=0 // NUMBER
var dtMaxParams = {
t: result, // INFOTABLE
columns:"'"+result.temp_min+"'", // STRING
aggregates: "MIN", // STRING
groupByColumns: undefined // STRING
var dtMax = Resources["InfoTableFunctions"].Aggregate(dtMaxParams); //INFOTABLE
//logger.warn(dtMax);
me.temp_min = dtMax.MIN_temp_min;
Finally, i can see me.temp_min is undefined!
Can you help me on this please?
Regards
Vikas
This parameter: columns:"'"+result.temp_min+"'", // STRING
Should be the column name: columns: "temp_min"
Yes, I tried but no luck!
Your previous code tries to aggregate from the DataTable not from the CSV, it's what you want to do?
I am getting data from csv and want to aggregate from there..
But you are aggregating from result instead of result1
Yes, But i tried both result1 and result.
Should work, would you send me the CSV file and I try it?
Can you send also the DataShape please (export xml)
Well on the meantime I was processing the file with another shape, and I didn't had any problem to get the minimum
var result = Resources["CSVParserFunctions"].ReadCSVFile( { path: "test_aggrigation.csv" /* STRING */, columnMappings: undefined,//"column1;column2;column3", hasHeader: false, longitudeField: undefined /* NUMBER */, dateFormat: undefined /* STRING */, fileRepository: "SystemRepository" /* THINGNAME */, latitudeField: undefined /* NUMBER */, fieldDelimiter: ",", stringDelimiter: undefined /* STRING */, dataShape: "aggrigateShape" /* DATASHAPENAME */ }); result = Resources["InfoTableFunctions"].Aggregate({ t: result, // INFOTABLE columns: "column1", // STRING aggregates: "MIN", // STRING groupByColumns: undefined // STRING });
Maybe the problem of your solution it's that you are setting a not created property --> me.temp_min did you previously created this property on the thing itself?
Brilliant, Thank you so much Carles for Perfect Solutions & Faster reply for me.
Best Regards
Vikas
Hi Vikas, I am in the same situation as you were before. I followed all the steps mentioned by Carles but couldn't resolve the issue can you please help me out on this?
