i want to show the combination of Bar and line chart on same graph
Suraj_Patil
i have two rows as output , now i using line chart for the same to show the graph
now here the requirement is,  want to show violet/scion color line graph as bar chart and gray color values as line chart how to achieve this combination is same widgets of chart
Hi @Suraj_Patil  For this requirement you can use a combo chart.
Take a look:
combo chart is available in 9.5 and above version only right?
Hi @Suraj_Patil  From 9.4 and above.
