Hi Community,
I have an edit button in my mashup for which I want to give an icon.But after I give my media in the icon property of the button and just click on another widget in the same mashup the icon property is empty again.Even after I tried saving it directly it is empty.Also it has a symbol in the media it which doesn't general occur when i upload other icons.You can check the images I have attached to understand that.What should I do?
Yes,I made a new media entity with a different name but same image and it worked fine.
I've actually never done it with the icon field ... but usually assigning a value, hitting enter or going to the next property field with a save should make it stick.
If it is not sticking at all as a work around you could put it in the style definition for now.
I'd report it as a bug
Okay,I shall try it as a style definition.
Hi @alenaromi.
Were you able to find an acceptable solution for your issue? If a case was opened, please let me know the case number.
--Sharon
I couldn't add a style def for icons.I noticed that when I changed the naming convention of the media entity it was getting saved.Thanks.
Hi @alenaromi.
After re-reading this post, it sounds like there may be an issue with your media entity. Have you tested with a different image?
--Sharon
Hi @alenaromi.
Glad you resolved the issue.
Please mark your post containing the solution as the Accepted Solution for the benefit of others on the community.
--Sharon
